Outward Normal (Direction Specification Method) of Mass Flow Inlet?
    • SEANGHAI
      Hello! Everyone! Can you tell what is the meaning Outward Normal (The direction specification method) of the mass flow inlet as in the following figure? Thank you!
    • DrAmine
      What about reading the documentation?n
    • SEANGHAI
      Yes! I already read it, but I am still not sure. this is why I come here. I think that when we use Outward Normal direction, it means that the mass flow rate going out from the domain with applied value of mass flow rate. And the boundary will be considered as the Outlet of mass flow rate, am I right?n
