December 1, 2019 at 10:55 am
Hava
SubscriberDears
I faced some a problems for the dimension while creating a geometry using ansys. once I build a rectangle inside a rectangle or circle for fourth dimension, I cannot change it gives me an over constraint.
If any one have any idea, please let me know
Thanks
December 1, 2019 at 1:09 pm
SubscriberPlease reply with screenshot images of the geometry and dimensions inserted into the post using the Insert Image button.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5364
3363
2471
1310
1018
