3D Design
3D Design
Overhanging constraint in the response surface optimization of a turbine blade
    • LucaMartorelli
      Dear all,
      I am working on a response surface optimization for my Master thesis and I would like to include a constraint accounting for overhanging issues during the manufacturing.
      In particular, I need to define an output parameter in DesignModeler (BladeEditor) that outputs the minimum inclination angle of the 3D turbine surface with respect to the horizontal xy plane. This parameter can also be defined in Static Structural since I use it in the optimization framework, but it has to output the overhanging angle of the initial geometry and not the deformed one.
      Does someone know how could I define such a parameter?
      Thanks for your time and help.
      Luca
Viewing 0 reply threads
