March 20, 2022 at 11:18 am
Asma_Nijhum
SubscriberHave you found any solution ?? I have also doing my grad thesis under kinda same topic and having problem !
March 21, 2022 at 11:34 am
Ansys EmployeeThe OPs problem is linked to the mesh quality, or rather lack thereof. What are you stuck with?
March 24, 2022 at 3:36 am
Asma_Nijhum
SubscriberWhen i am attaching the geometry the two attached body is having a mysterious gap which kinda like overlapping. Then two adjacent wall is not heat transferring .
March 24, 2022 at 3:59 pm
System
SubscriberThis discussion was created from comments split from: Modeling heat transfer in nuclear reactor's fuel rod. -
March 24, 2022 at 4:00 pm
Ansys EmployeeCheck the CAD in the geometry tool. You may want to use DesignModeler and then form a multibody part. It sounds like the common faces of two volumes aren't as closely connected as they should be. If the overlap is too great you'll need to use a Boolean and/or split to fix it.
7742
4502
2963
1449
1322
