October 19, 2021 at 11:27 am
syed.ali
SubscriberHi, Can you possibly answer this. Did a specific load case sim on the same frame and I would like the scale to higher than what Discovery brings up. This is the results and the scale it shows by default. I would like to override the scale and have it show 0 to 1.0 rather than 0 to .30852 This way nothing on the image will be red which looks bad even though the number is very small. I would then use the different scale image for a customer report, which again would look better as it would not show red. I cannot seem to do this ? Is this possible ? Thanks, Ali
October 19, 2021 at 11:41 am
Charudatta Bandgar
SubscriberHello Syed Saif Ali
You can click on the first value on your contour (0.30852mm in your case) and make it 1 to get the desired contour. Please check and let me know if that is what you were trying to get.
Regards.
October 19, 2021 at 11:56 am
syed.ali
SubscriberHi Charudatta Bandgar ,
I tried that way back and it didn't worked.
October 20, 2021 at 4:56 am
Charudatta Bandgar
SubscriberSyed Saif Ali Hello, Apologies for the confusion, the contour can not pick a value greater than the maximum value the way you want. We thank you for sharing your feedback. We will share your idea/input with the product development team. Regards.
October 20, 2021 at 10:38 am
syed.ali
No worries,
Thanks for the answer.
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Unexpected graphics error
- loss of user settings
- Dwg export error
- Can’t see license on online account
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- problem to access on the spaceclaim help
- Unsymmetric result
3720
2570
1773
1236
594
