Ansys Products
Ansys Products
Overset Model is Not Compatible with SIMPLE Method
    • Zakaria Rahmanu
      I have an error notification in ANSYS Fluent that the overset model is not compatible with the following settings: pressure velocity coupling "simple". Anyone know this problem, and how to solve this problem? Thank you
    • Federico Alzamora Previtali
      which version of Fluent are you using?
      According to the 23R1 manual, SIMPLE pressure-velocity coupling should be compatible 6.7. Overset Meshes (ansys.com)
    • Zakaria Rahmanu
      I am using ANSYS Fluent 2020 R1 version. I can't change the pressure-velocity coupling, except Coupled Method
      Had a look at the 20R1 manual, and it does say to use the Coupled scheme for pressure-velocity coupling.
      Please try it and let me know if it works for you.
Viewing 3 reply threads
