March 19, 2021 at 10:06 pm
AleC
SubscriberHi everyone, I'm trying to simulate the performance of an OWC system (oscillating water column) inside a waves tank generator but at the end of the simulation, I find inside the chamber levels of the free surface that exceed those reached from the current outside the chamber. this shouldn't happen so I'm going to report the steps I did hoping someone can help me:
first this is the mesh I used:
March 20, 2021 at 6:00 amYasserSelima
SubscriberI am not sure if this is the reason or not, but surface tension value is too high ... I believe you meant 0.072 N/mnMarch 20, 2021 at 9:34 amAleC
SubscriberI am not sure if this is the reason or not, but surface tension value is too high ... I believe you meant 0.072 N/mhttps://forum.ansys.com/discussion/comment/111697#Comment_111697
you're absolutely right, but unfortunately that is not the mistake, after fixing the surface tension nothing has changednNovember 29, 2022 at 3:36 amNazmul Islam Nishat
Subscriberwill you give me your case file?
gmail:nishatni0175@gmail.com
2726
2156
1359
1150
462
