February 28, 2017 at 9:28 am
Nikita
Ansys EmployeeHow do I package multiple components into one assembly to send to a client in SpaceClaim Engineer?
August 25, 2017 at 9:35 pm
pgl
Ansys EmployeeIn order to send a client an assembly model properly, you need to make sure that all your components have been internalized. Click on a component in the Structure tree with the right mouse button and select "Use Internal Copy" to make it internal. Finally, save your assembly and send the resulting SpaceClaim document to the client.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
