June 17, 2020 at 11:38 pm
tyson.cooney
SubscriberHi,
I'm attempting to model a packing gland. When the gland is compressed it squashes onto the cable providing a pressure seal. The aim is to apply enough "squash" to create a seal on the cable, but not so much that it ruptures the cable. I have the following issues and questions
1. At 1.5 mm of displacement the gland makes contact with the cable, and the model solves with only some minor warnings, but no errors. At 3.0 mm of displacement I get errors, see below. I have made the suggested adjustments to the model but still receive the errors.
2. Is there a way to identify where element 13485 is? Does AIM progressively remesh the model as the geometry deforms?
3. Is it worth using a neo-hookean material?
4. I have archived the model, but couldn't attach it to this message.
Errors
Physics 1: Mapdl solving has failed.
Physics 1: Initial contact status for Contact 3 is near open. Consider setting the initial contact treatment to Fix unintentional initial gap/overlap in the solver settings, or refer to the Troubleshooting Structural, Thermal, and Electric Conduction Simulations section of the documentation for advice.
*** ERROR ***
Element 13485 (type = 1, SOLID186) (and maybe other elements) has
become highly distorted. Excessive distortion of elements is usually
a symptom indicating the need for corrective action elsewhere. Try
incrementing the load more slowly (increase the number of substeps or
decrease the time step size). You may need to improve your mesh to
obtain elements with better aspect ratios. Also consider the behavior
of materials, contact pairs, and/or constraint equations. Please rule
out other root causes of this failure before attempting rezoning or
nonlinear adaptive solutions. If this message appears in the first
iteration of first substep, be sure to perform element shape checking.Regards
June 18, 2020 at 4:26 am
Charudatta Bandgar
SubscriberHello T-C ,
I have sent you a secure transfer link, where you can send the AIM simulation archive file.
June 19, 2020 at 8:20 am
Charudatta Bandgar
I reviewed your model and this response will enlist all the probable reasons for the partial convergence.
In my opinion, the mesh at the lowermost area of the gland has coarse mesh, by refining the mesh near the contacting faces and higher distortion region might help in solving the problem. You can also further increase the number of substeps for the simulation.
There is not an inbuilt tool to find a particular element in AIM. Discovery AIM also does not have adaptive meshing, which would progressively refine as the geometry deforms.
For this problem, I think Neo-Hookean hyperelasticity would help, and it is possible to define it in AIM as well.
June 29, 2020 at 9:26 am
Charudatta Bandgar
Were you able to get full convergence with suggested changes?
Regards.
3850
2629
1853
1246
600
