October 17, 2018 at 5:51 pm
mashimaro_star
SubscriberDear All,
I met an interesting errors when I use the dynamic mesh plus DPM simulations (only with 1 udf which defined the particle time step).
"dynamic mesh fluent 999999: mpt_accept: error: accept failed: No such file or directory". This came at the time when the unsteady airflow field converged. So I am guessing it is the problem because of the unsteady particle tracking.
I checked the case with only the airflow simulation and dynamic mesh, no errors interrupted the simulation.
The particle number injected is around 50,000 (5 injections at 5 time stations using injection files written by ourselves).
Could you please see if there is any solution for this kind of problem? Should I switch the parallel mode for DPM? Thank you. Best regards
October 19, 2018 at 4:17 am
Keyur Kanade
Ansys EmployeeHello,
Is your problem solved as seen on other thread.
https://forum.ansys.com/forums/topic/2-6971-of-the-total-discrete-phase-mass-was-not-tracked-for-the-expected-residence-time/
Keyur
October 19, 2018 at 4:58 am
mashimaro_star
SubscriberHi Keyur,
Thank you for asking me. Not yet. Should I follow the same advice and expect the this problem to be solved? Thank you. Best
October 19, 2018 at 5:38 am
DrAmine
Ansys EmployeeDoes the error happen within the first time the particles are injected?
October 19, 2018 at 5:49 am
Keyur Kanade
Ansys EmployeeHi,
Which version you are using?
Thought I dont know your exact case, few generic guidelines are as follows.
Looks like you are using file injection. can you please check if you have read - write permissions to the corresponding folders and files. Please make sure that you dont have any spaces or special characters in folder or file name.
Can you please try surface injection and test it.
Can you please set it up in serial and then run in parallel.
Keyur
2524
2066
1279
1096
459
