July 1, 2020 at 6:19 pm
ecrod
SubscriberI have a machine with two Intel Xeon E5-2620V4 processors, 8 cores each . And a SVGA Nvidia RTX 2070/8GB.
1. Am I able two run Fluent in parallel using 16 cores for instance ?
2. In this case, I will run on a single machine. Do I need to install Intel or IBM MPI ?
3. Can I use GPU for the solver ?
Thanks in advance
July 3, 2020 at 12:26 am
tsiriaks
Ansys Employee1.It's recommended to turn off hyperthreading and just use physical cores. So, your total would be 8.
2.Running locally doesn't need extra MPI installation, they already come with your base Fluent installation.
3.That card is not tested, ref:
https://www.ansys.com/-/media/ansys/corporate/files/pdf/solutions/it-professionals/platform-support/gpu-accelerator-capabilities-2020-r1.pdf?la=en-in&hash=85106E5CFA8A60D6C6CBC7F6B4A910CF3397DE7D
but you can try. However, you may need to check with Fluent expert what kind of analysis can benefit from it. It's not applicable to all.
July 3, 2020 at 12:57 pm
ecrod
SubscriberThank your answer.
I really did not understand the answer in question 1. I have two "physical" processors with 8 cores each, totalizing "16 physical cores". Why if I turned off hyperthreading I would be able to use only 8 cores ?
As far as I know, with hyperthreading on I would have something like 2x8 for each processor, totalizing "32 unphysical cores".
If turned off hyperthreading, I tought that I would have 16 cores to run, am I right ?
July 3, 2020 at 2:32 pm
DrAmine
Ansys EmployeeYes you will still have you physical 16 cores which you can use. We do not recommend using hyper-threading.
Regarding GPU: speed-up only noticeable if there is critical percentage of time spent by GPUs on linear solver (more than 80%).
July 3, 2020 at 2:40 pm
ecrod
SubscriberThank you a lot.
I will turn off hyper-threading.
Best Regards.
July 6, 2020 at 11:18 pm
tsiriaks
Ansys EmployeeTo make sure about your max number of cores that you can use, do you mean your machine has 2 CPU sockets ?
What is the output of the following command
WMIC CPU Get DeviceID,NumberOfCores,NumberOfLogicalProcessors
3744
2573
1821
1236
594
