August 3, 2018 at 9:40 pm
August 3, 2018 at 10:57 pm
klu
Ansys EmployeeHi,
Please try removing those lines by applying in the TUI window this command:
(cxg-stitch-shells)
including the parenthesis.
Thanks.
August 5, 2018 at 10:25 pm
Konstantine Kourbatski
Ansys Employeeany time you post a question, please specify a version of the code you are running as a solution can differ by version. E. g. in R17.0 and later, you can:
/display/set/duplicate-node-display? yes
in R16.x, you need to turn on beta features before running the above command
/define/bfa yes ok
In R15.0 and earlier, use (cxg-stitch-shells) posted bu klu
2600
2088
1319
1108
459
