July 22, 2019 at 12:13 pm
July 22, 2019 at 12:30 pm
Ansys EmployeeIt's not the variables that cause you to need parallel, it's the loop operations.
July 22, 2019 at 12:38 pm
xqzhang
Subscriberthanks for your reply. but in the manual, it says "varials used by serial, host, node versions" and "these variables are not available on the host" just like the picture.
July 22, 2019 at 1:37 pm
DrAmine
Ansys EmployeeThe manual does only tell that some parts won't be seen by HOST or NODE or whatever depending on the compiler directives.
!RP_NODE will be only executed by Host or Serial for example
Host does not contain any data or mesh info it just communicates with the Cortex/UI. Nodes have mesh and data info. Nodes communicate with Host via Node 0.
I recommend attending a UDF training.
July 22, 2019 at 2:03 pm
xqzhang
July 22, 2019 at 2:23 pm
DrAmine
Ansys Employeewelcome!
2524
2066
1279
1096
459
