Parallelizing a DEFINE_PROFILE UDF
    • MohammadUT
      Hello, I have two questions  and I would be very thankful if you take time and answer them.
      1-Does host is executed when reading a DEFINE_PROFILE UDF? because these same lines on this type of udf doesn't show the same result as an ONDEMAND UDF:
      	#if RP_HOST
      Message("n I am in the host processn");
      #endif /* RP_HOST */
      #if RP_NODE
      Message("I am in the node process with ID %dn",myid);
      /* myid is a global variable which is set to the multiport ID for
      each node */
      #endif /* RP_NODE */
      result of DEFINE_PROFILE:
      I am in the node process with ID 0
      I am in the node process with ID 1
      I am in the node process with ID 2
      I am in the node process with ID 3
      I am in the node process with ID 4
      result of DEFINE_ON_DEMAND:
      2-Do we need Host to set an RP-Variable in udf or it is node's job? If we need host for that considering question 1, what should I do to get this UDF that works fine in parallel with zero nodes, does the same with more nodes?
      DEFINE_PROFILE(udftransient,t,i)
      begin_f_loop(f,t)
      F_PROFILE(f,t,i) = massfr;
      end_f_loop(f,t)
      RP_Set_Real("qintudf",(massfr/998.2)); // this line does nothing in parallel with 2 or more nodes
      thank you in adavance.
    • DrAmine
      You did the test and it shows that is not executed. I will try to sync host with node processes. Perhaps this is not required with you to your variable.
      For further debugging start Gluent with zero cpu: that is the old serial solver.
