Preprocessing
Preprocessing
Parameter Expression in DesignModeler too long
    • hansophxy
      I am currently working with the Ansys DesignModeler and I have a rather complex geometry. In order to compute the required variables for my geometry, I have to define a very long expressions inside my parameter dimension assignment window. Unfortunately it seems to cut off the end of my expressions, resulting in an invalid syntax error for my expression.
    • Aniket
      can you use SpaceClaim instead?
      Would you be able to use the expressions in the workbench instead to calculate final parameter value for DM?
      -Aniket
