Process Integration and Design Optimization
Parameter relationships for Optimization
    • WolfgangNeil
      I want to set a volume parameter relationship between the inputs in terms of internal length, width and height of a hollow cuboid. As represented in the screenshot below within the red highlighted rectangle, I can only parameterize the inputs with 'less than equal to' or 'greater than equal to' operator.
    • John Doyle
      I confirmed what you report. It appears to be a limitation. I am not aware of a workaround.
    • WolfgangNeil
      I managed to come across this issue by mentioning the same expression within the Parameter Set window.
    • clabr
      Hi I am having a very similar problem. Could you explain better how you solved it?
      Thanks
    • WolfgangNeil
      In the Parameter set window and within input parameters, enter the "New Name" in the "Parameter Name" column. A new Properties of Outline will appear below the table. Enter the "Expression" to relate desired parameters and proceed.
Viewing 4 reply threads
