February 28, 2022 at 5:28 pm
hernandez.triana.jl99
SubscriberHi everyone
It´s my first time using ANSYS software. I need to parameterize a scheffler type solar colector using Spaceclaim (look at the scheme). The scheffler type solar colector is maked by a parabolic surface cutted by a 45° inclined plane, so I want to parameterize it based in two variables, the reflector focal lenght (the variable that parameterizes the parabolic curve plane callednamed "Df") and the reflector area (which depends on the variables "Df" and the a variable that parameterizes the cutting plane called "C"), so i have some questions about that.
March 2, 2022 at 3:10 amKeyur Kanade
You can use equation to create curve. Please check documentation.
Regards Keyur
March 2, 2022 at 12:25 pmpeteroznewman
SubscriberConstruct a parametric conical surface, and a parametric plane to make a vertical slice. The edge of the cut is a parabolic curve. Revolve that to make a fully parameterized parabolic surface. Create another parametric plane a distance C below the vertex and tilted at 45 degrees. Use this plane to slice out the fully parametric off-axis reflector.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2150
1359
1150
462
