Platform
Platform
Parameterization Update Problem for New Design Points
    • Raj007
      Hello guys,
      I have a model with a velocity-inlet and outlet. The input parameters are velocity, temperature, and radius. The output parameters are heat flux and shear stress.
      When I am adding the new design point for the parameter, I am getting the following error
      "Update failed for the Solution component in 2dfil for Design Point 135. Update Solution Failed"
      and there is no output result.
      Please help me or suggest a possible solution to generate new design points.
      Thank you
      Raj
    • Keyur Kanade
      please make sure that your geometry and mesh is valid for each design point.
      you can check it opening independently.
      Keyur
    • Raj007
      Sorry, I did not understand. Can you please elaborate and explain in detail?
      Thank you
      Raj
      Click on a Design Point, and check the geometry & Mesh manually. Hopefully this will fail so you can figure out what's wrong by looking at the geometry/mesh.
    • Raj007
      You can see the error (in the picture), which is the same as I mentioned.
      Sorry. But I could not find any option as you have suggested. If I understood wrong, please excuse me.
      Thank you for your response.
    • Keyur Kanade
      select failed design point. right click and select set to current.
      then open geometry and check if geometry is valid.
      open mesh and check if mesh is valid.
      Keyur
Viewing 5 reply threads
