May 14, 2023 at 3:16 pm
Aswathi Sampanraj
SubscriberIn ansys fluent we usually enter the material properties. In my case I wanted to vary the thermal conductivity and check how the temperature output of the system varies accordingly. But right now I am only able to enter manually one value of thermal conductivity and check the temperature output. How can we enter a range of values and check the temperature output in fluent?
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- pcb
- problems facing during solution
- Still facing the same issue
- Simulation of a single pillar of a peltier cooler
- Ansys Sherlock Mechanical Shock and Vibration Analysis Error
- Extraction of parameters of mosfet
- Simulation of MoS2 with Au Nanoparticles
- Simulation For Solar Module
- Apache Timing Engine error message
5290
3311
2471
