August 23, 2018 at 6:14 am
Ananth Narayan
SubscriberHello, may I know the procedure for importing parameters from catia to ansys. I tried a lot but doesnot work well. It will be useful if you have a video attached or pictures.
Regards, -
August 23, 2018 at 6:27 am
Naresh Patre
Ansys EmployeeHello Ananth,
Check out below video on How To Create Named Selections and Parameters in CATIA and import them in Workbench
August 23, 2018 at 6:48 am
Ananth Narayan
SubscriberThanks nmpatre -
June 5, 2019 at 12:41 pm
xavierBAM
SubscriberDon you need to have CATIA and ANSYS in the same computer? Because I´m working in two different computers and trasnfering the file from one another
June 19, 2019 at 3:26 am
Ananth Narayan
SubscriberNeed not to be. You can save catia file and import to ansys on another system.
June 19, 2019 at 7:43 am
xavierBAM
SubscriberYes but, can you export the parameters? it just that I think ANSYS changes the geometry by calling the software, so if the software it's not there it won't be able to do so.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
