Tagged: discovery-live, excel, parameters, python, study
October 17, 2021 at 7:54 am
seghier
SubscriberHello
Is it possible to import excel or csv file to use it as Parameters study?
Or with Python if it is possible?
October 17, 2021 at 4:21 pmpeteroznewman
SubscriberCopy from Excel, Paste into Parameter Table of Design Points.
October 17, 2021 at 5:00 pmOctober 18, 2021 at 12:28 ampeteroznewman
SubscriberOpen the Project in Workbench.
October 18, 2021 at 12:55 amseghier
SubscriberThanks peteroznewman
I did that but i don't know how to update and update parameters study values in discovery live.
Can you please show me a simple example or a clear tutorial avaialble ?
October 18, 2021 at 5:43 amOctober 18, 2021 at 12:15 pmpeteroznewman
SubscriberI don't have Discovery Live installed and don't use it. See if the following video helps.
https://forum.ansys.com/discussion/1297/changing-dimensions-programmatically-and-running-simulations
October 18, 2021 at 12:49 pmseghier
Sadly the video don't help, workbench update the geometry and create different files but don't update the list of values in discovery live
I hope they add an option to import excel file or at least allow modification via python.
I tried this without success
October 18, 2021 at 1:42 pmMarch 17, 2022 at 2:44 pmseghier
SubscriberI find a solution, maybe someone need it , using Group.TryGetDimensionValue
and this can used from external Python editor with other settings from Unsupported.Live
Viewing 9 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2630
2110
1335
1110
461
