Parameters unchanged even when WB Associative interface runs okay
    • SaiD
      Why do parameters remain unchanged even when WB Associative interface for SolidWorks runs fine?n
    • Kai
      In SolidWorks, under Equations panel, please check if the parameters are locked. When the parameters are exported to external file and linked with external file (such as *.txt), they are locked and can not be updated. The above issue can prevent the parameters in WB remain unchanged even after WB associative interface for SolidWorks runs fine.n
