3D Design
3D Design
Parametrezation In ICEM
    • alimjalled
      Hello Everyone,
      I created a parametric geometry in SpaceClaim and I want to mesh this geometry in ICEM. I want that the Mesh automatically generates when I update the geometry by changing the parameters. I gave name to almost every important line in my geometry for the Mesh, they all appear in the PART tree in ICEM.
      I did the mesh in ICEM manually and recorded the script to see the basic commands I want to perform. The problem is that the naming of the curves is completely different than what I want. For example I have INLET line, when I select it it appears EDGEExx. I have also one wavy line ( crated from spline in spaceclaim), it's divided into many edges.
      So basically the problem I am facing is that the number of edges depends on the geometry parameters and I want to generalize my script but I don't know how to do that. I hope that you can help me in solving my issue.
      Thank you in advance
    • Keyur Kanade
      It would be different. What is application?
      Please use SpaceClaim --> Ansys Mehsing in WB for parameteriziation.
      Please go through help manual for more details
      Regards Keyur
    • alimjalled
      But I have problem with Inflation when I do meshing in Ansys Meshing. To have a structured Q4 mesh, I want to use face meshing, and when I use face meshing the inflation is not active. Am I doing something wrong ?
      Thank you
    • Keyur Kanade
      If you are going to use it for Fluent, can you please check if you can use tet + inflation?
    • alimjalled
      Yes it's fine and I can use it, but I also have a problem which I posted in another thread: https://forum.ansys.com/discussion/comment/118018#Comment_118018. When I make another design point and I run the simulation, and
      set it as current and check the mesh, I can't see inflation, so why the inflation control is not transmitted to other design points ? The inflation is set to Named selection.
      I Really appreciate if you can help me in this, since it's crucial point in my thesis.
      Thanks in advance.
    • alimjalled
      Only in this example I used geometry selection for the face, but in my project it's also face selection and changed nothing.
    • Keyur Kanade
      If you are using Face meshing, you can use edge biasing to get inflation effect.
      Regards Keyur
    • alimjalled
      Yes I know that I can do biasing and I know also how, but can you tell me please how to make it from both sides ? is it possible without splitting the edge in 2 halves ? I want to perform the same mesh posted below and I want just guidelines.
      Thank you
    • Keyur Kanade
      Yes, you can give bias from both sides. Under bias you can select it.
Viewing 8 reply threads
