Parametric analysis for the model with variable distance relative to the ground plane
    • Hozaifa
      I am simulating a dual band antenna with ground plane, I want to change the distance between the model and the ground plane,, and I have the model as one 3D item, I want to change the distance between the model and the ground plane by moving the model up and down, can I define one point in the model as reference point and assign variables to this reference point..!!!!!! or any other fast way rather than define the model with variables from the beginning
    • Chinmay T
      Please follow the below steps:
      Select all the objects you want to move.
      In the Draw tab, select the Move command to move the objects.
      In the move vector field, you can define a variable and perform a parametric analysis.
      Please go through the "Moving Objects" section from the HFSS Help document.
      Thanks Chinmay
