parametric analysis setup or designXplorer setup
    • okara
      I have magnetostatic anaysis of maxwell project. I require to move magnet system and sensor on the material along the Y direction and want to get magnetic field density values with respect to horizontal position (for each mm) of magnet system. I made the adjustments of field calculator to calculate magnetic field, but could not get the values respect to magnet system.
      I little bit know that I require to build parametric analysis setup or designXplorer setup but how ?? If I am wrong with this idea, what I suppose to do to get the magnetic field values ?? Thanks.
    • peteroznewman
      It would be easier to move the material in the -Y direction than to move all the other parts in the +Y direction.
      You can create CAD parameters in DesignModler or SpaceClaim to position the material by a dimension.
      You can put a list of positions in the Workbench Parameter Set and solve for all of them.
    • okara
      why ?? what is difference moving the magnetic system -Y direction from +Y direction ?
