January 25, 2023 at 6:24 pm
Angel Cerrada Ramírez
SubscriberDear all,
I'm trying to optimize the parameters of a Frequency Selective Surface using a program written in Java that I've been sent. But first, in order to do that, I'd like to be able to generate a file with a set of parameters and their values (with a proper sintax), feed HFSS with that file to run the simulation, and be able to read the results in Java.
I have some questions in this regard:
- What kind of file and format to use to feed HFSS.
- How to run the simulation from the written file.
- How to read the results, for example the S-parameters.
Thakns in advance,
Best regards,
Angel
- Maxwell, HFSS or Q3D?
- Error
2522
2064
1279
1094
456
