October 29, 2018 at 7:44 am
October 29, 2018 at 1:49 pm
mchristi
Ansys EmployeeJust set the linear permeability to a project variable such as: $perm and you can sweep it the same way as with any other variable. (Material variables need the $ prefix since they work at the higher project level instead of the design level.)
- Maxwell, HFSS or Q3D?
- Error
2700
2138
1355
1142
462
