Parametric Result analysis
    • skdubey
      Dear Friends,
      Recently I am working on my fluid flow simulation and encounter fews doubts :
      a. During the parametric analysis of my fluid at different inlet pressure, i would like to see my result for each design point. I click on the "set as current" and then update in the work bench by clicking the post-cfd as "update", I cannot see any results. I am struggling is there anything I am missing: Do I need to load the result for each design point in the "load option in the CFD Post(File)"
      b. Anysuggestion I am getting pretty long name in  the interface, I want to reduce that in order to work on my simulation in more better way.
    • Federico Alzamora Previtali
      for b), depending on how you are getting those names, you might be able to do some clean up with TUI commands, e.g. (tgapi-util-clean-face-zonenames). See Fluent Text Command List (ansys.com) for additional options.
    • skdubey
      Okay @federico
