February 17, 2023 at 5:32 am
skdubey
SubscriberDear Friends,
Recently I am working on my fluid flow simulation and encounter fews doubts :
a. During the parametric analysis of my fluid at different inlet pressure, i would like to see my result for each design point. I click on the "set as current" and then update in the work bench by clicking the post-cfd as "update", I cannot see any results. I am struggling is there anything I am missing: Do I need to load the result for each design point in the "load option in the CFD Post(File)"
b. Anysuggestion I am getting pretty long name in the interface, I want to reduce that in order to work on my simulation in more better way.
February 17, 2023 at 10:04 am
Nikhil Narale
Ansys EmployeeHello,
Did you get a chance to check this tutorial video:
See if that helps.
Thanks!
Nikhil
February 17, 2023 at 3:30 pm
3728
2570
1783
1236
594
