Kampus Merdeka
Kampus Merdeka
Parametric Ribbon Missing [help]
    • Julian Martinez Saah
      hi all
      I want to run a parametric analysis inside Fluent because from workbench all i get is "failed to update design point X" after 2 minutes without further information.
      But i can't see that option [Parametric] on the ribbon task, i'm using 2020 R2
      Any help would be appreciated
    • Raihan Lutfianto
      Hi Julian, could you please share your Workbench Schematic? Also, more information regarding your parameters is needed (what your parameters are, how you define the parameters, etc.). What about running from Fluent "standalone" app? I am using the 2023 R2 and the Parametric tab can be found as shown below.
