November 7, 2023 at 7:36 am
Michael Aeschbacher
SubscriberI created a project to simulate the influence of an inductive solder coil to our PCB. For this I have a transient analysis with external schematic. To get a good mesh I created an EddyCurrent simulation with the identical geometry and schematic and linked it to the transient simulation.
Now I want to simulate different setups which I can configure with project variables. I did parametric simulation with different test coil sizes and distances between solder coil and PCB but the result is always the same.
I get two warnings during the simulation (see picture below). May these be the reason for identical results in simulation? How can I solve these warnings? I don't understand what the problem is.
I would attach my project here, but I don't see the possibility to attach a file to my post.
I hope someone can help me. Let me know if you need more information.
November 8, 2023 at 7:29 pm
GLUO
Ansys EmployeeHello,
The warnings is from one of your object created with UDP. You could select the object, go to modeler>>purge history to get rid of the warining.. I do not think this is related t your result. If you would like to have an engineer check your project, please use the support button at the left of this page.
GL
- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3153
1680
1470
