Tagged: p, parametric, parametric-analysis, parametrization, parametrize
February 28, 2022 at 8:19 pm
juan_david_barragan
SubscriberHello everyone,
I am a beginner in SpaceClaim. So i want to draw a sketch with parametrical dimensions. But i couldnt figure out how to do it in SpaceClaim. I am a pro level solidworks-inventor user and i can do it in these cad softwares so easily. But SC dont let me dimension my sketch . And i've created some parameters but couldnt assign them as dimensions too. Please help me.
Thank you.
Juan David
March 1, 2022 at 3:07 pmKarthik R
AdministratorHello:
You should be able to find several video resources on this topic if you search for the following keywords - "spaceclaim parametric dimensions". Please let us know if this helps.
Karthik
March 1, 2022 at 4:30 pmjuan_david_barragan
SubscriberI didn't find information on how to parameterize in two dimensions, I have a parabolic curve but I can't parameterize it in the sketch, I have ansys 2022 and this problem is supposed to be similar to others (I did not find information on how to parameterize in two dimensions, I have a parabolic curve but I cannot parameterize it in the sketch, I have ansys 2022 and this problem is supposed to be similar to others (https://forum.ansys.com/discussion/15739/parametric-sketch-in-spaceclaim-19) and features were added to the latest versions of ansys) that features were added to the latest versions of ansys.
March 1, 2022 at 4:35 pmjuan_david_barragan
SubscriberI didn't find information on how to parameterize in two dimensions, I have a parabolic curve but I can't parameterize it in the sketch, I have ansys 2022 and this problem is supposed to be similar to others (https://forum.ansys. com/discussion/ 15739/ parametric-sketch-in-spaceclaim-19) that features were added to the latest versions of ansys.
March 2, 2022 at 12:02 pmViewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2662
2120
1349
1130
461
