October 25, 2021 at 12:21 pm
DhruvP
SubscriberI have prepared a model in ansys workbench and done fea analysis on that when i try to do the parametric study of the model by connecting my dished end thickness to the equivalent von mises stresses this message pops up
"(DP 1) The Model component in better meshing try 1 for Design Point 1 requires user input before it can be updated. For instructions on how to address the cell in its current state, click the blue triangle in the lower right corner of the cell in the Project Schematic. Set the design point as current to see the state at the point of failure." PFA
October 27, 2021 at 11:20 amAniket
Ansys Employeewhat happens when you click on update all design points?
-Aniket
October 27, 2021 at 1:54 pmGovindan Nagappan
Ansys EmployeeAs suggested in the message, right click on DP1 in parameter window and select "set as current". Then go to project schematic and refresh the cells. Open the model and see if there is any object in the tree that requires an input
November 9, 2021 at 10:15 amDhruvP
SubscriberSame error shows up !!!
November 9, 2021 at 10:17 amDhruvP
"set as current " option is not available ! is there anything else I can do to eliminate this ??
March 22, 2022 at 1:53 amryanortiz88
Subscriberany update on this ? I have the same issue
thanks!
March 23, 2022 at 11:18 amAniket
Ansys Employeehave you tried the 's suggestion of making a DP as current and then checking if any of the cells require any inputs from user?
-Aniket
Viewing 6 reply threads- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2600
2086
1317
1108
459
