November 20, 2018 at 2:54 pm
carlosdolz258
SubscriberHi I am relatively new to ANSYS and I have been designing a brake disc and pads and then analysing it. I wanted to change the thickness of the disc and to do so I need to increase the length of extrusion and also increase the distance of the reflection plane so that the pads also move. I parameterised this but when ANSYS creates random Design points at Parameter Correllation the system stops working becaouse the pads and disc are not in the correct positions. Is there a way to create 2 input parameters so that one depends on the other? in this case :
Position of Plane of Reflection*2= Thickness of the disc
Thanks
November 20, 2018 at 3:59 pm
Sandeep Medikonda
Ansys EmployeeHi,
Yes, you can parameterize it in SpaceClaim, here are a couple of good videos showing this:
Additionally, see this playlist: https://www.youtube.com/playlist?list=PL0lZXwHtV6OlOlR7HK70S4QPJILbnNqEl
Sandeep
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1347
1118
461
