3D Design
3D Design
Parametrize a geometry in SpaceClaim
    • Idence
      I would like to create a parametrized geometry. It's a cube with a smaller cube inside. The smaller cube shall be 1 mm smaller than the bigger cube. I try to archieve that this 1 mm always stays 1 mm, even when I change the dimensions of the bigger cube.
      Here you can see the two cubes I described.
    • Rahul Kumbhar
      You can create the two parameters each for outer box thickness and inner cube height. Then in Workbench, you can define a relation between them using Parameter manager.
    • Idence
      Thanks.
      Defining relations in Spaceclaim is not possible?
    • Rahul Kumbhar
      Not in Spaceclaim. Once you define the parameter in Spaceclaim, it is also shown in Parameter manager in Workbench. You can define the relation in parameter manager in Workbench.
Viewing 3 reply threads
