Tagged: ansys-fluent, ansys-student, cfd, dpm, results
March 7, 2022 at 8:09 pm
Lylad
SubscriberHi, I have a question about the units of DPM concentration when looking at particle flow results.
I understand that the units are in kg/m^3 however I am confused at what the mass means as I have not provided a mass for the particles?
Also, is there a way to show the particle results as number of particles per cubic metre on ANSYS fluent as that would be easier to understand.
Thanks sorry for all the questions I just need clarification on how to interpret my results :)
March 8, 2022 at 11:45 amRob
Ansys EmployeeThere is a mass flow associated with the injection, default is 1e-20kg/s. Given we track parcels, and that these can be different sizes, weights etc count per cell or per m3 isn't much use in most cases.
March 8, 2022 at 4:10 pmLylad
SubscriberHi Rob, thank you so much for your reply so the weight part of the units (kg/m^3) is taken from the mass flow ?
So would it be more accurate if I calculate the mass flow rate for my particles ?
Sorry for all the questions :)
March 9, 2022 at 3:56 pmRob
Ansys EmployeeIt's taken from the parcel mass and cell volume: there's an explanation (of sorts) in the manual, https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/flu_ug/flu_ug_fvdefs.html
2564
2068
1289
1106
459
