August 12, 2019 at 10:24 pm
soloviev
SubscriberHello,
I am running a model in which I am trying to inject particles on a surface. I have tried setting the injection time to 0 and 1 s and stop at 1 and 2 seconds, respectively. The particles are not injecting at the specified time.
Thanks,
Alex -
August 13, 2019 at 5:00 am
DrAmine
Ansys EmployeeHow are then the particles injected? -
August 13, 2019 at 2:45 pm
soloviev
SubscriberThe particles are not being injected at all. I am confused as to why they're not.
Thanks,
Alex -
August 14, 2019 at 4:54 am
DrAmine
Ansys EmployeeCan you add screenshot of the point injection panel. By opening injection panael please hit on list. Do the lines printed make a sense -
August 14, 2019 at 6:59 pm
August 15, 2019 at 5:43 am
DrAmine
Ansys EmployeeSo injection would start at 1 second and finishes after 2 seconds. You are using a total flow rate equal to 1e-20 kg/s: is this desired? Is the injection a placeholder injection or container for VOD-to-DPM particles?
August 15, 2019 at 4:39 pm
soloviev
SubscriberI have been trying to look into the users guide to find what exacly what setting this flow rate means for the particles. In this case I am trying to actually inject particles from a surface, not a placeholder for vof to dpm.
Thanks,
Alex -
August 15, 2019 at 5:20 pm
DrAmine
Ansys EmployeeThen it has to correspond to the total flow rate if the injection. Particle tine step size or flow time step size times that quantity correspond to the mass injected into the domain if carrying transient tracking. If I remember if you enable beta feature you might directly provide the mass. -
August 15, 2019 at 6:55 pm
soloviev
SubscriberI looked online for how to enable beta features, but couldn't find out how for standalone fluent. Could you give any direction in how to do so?
Thanks,
Alex -
August 16, 2019 at 6:01 am
DrAmine
Ansys EmployeeTo enable beta features in the Fluent console you go to the menu define then type bfa and answer the questions.
August 16, 2019 at 4:31 pm
soloviev
SubscriberThank you, it seems these suggestions solved the issue. One last question, is there a way to specify the number of particles injected?
Thanks,
Alex -
August 17, 2019 at 7:20 am
DrAmine
Ansys EmployeeThat has to Do with the injection method under parcel method used . A brief ansewer yes. More details in the help where you can describe if you want to fix number of particles per parcel or mass or diameter or use standard which I recommend for you case. You can fix number of injected parcels for some injection methods and for surface injection too (beta) -
August 20, 2019 at 2:32 pm
soloviev
SubscriberThank you!
-Alex
2666
2120
1349
1132
461
