December 8, 2022 at 9:19 pm
ll00023
SubscriberIn Fluent help, the equivalent particle scattering factor is defined in this way.
we have emissivity, absorptivity, and scattering.
I don't understand the difference between the equivalent particle scattering factor and scattering factor f_pn. why using (1-f_pn)?
Another question is how it is associated with the volume.
December 13, 2022 at 2:25 pm
Ansys EmployeeI suspect it'll be a maths definition somewhere, and may be defined in more detail in a reference given at the top of the section https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v222/en/flu_th/flu_th_sec_mod_p1.html%23flu_th_radiation_p1_particles
The heat sink (source) to the fluid volume is given at the end of the above.
December 13, 2022 at 3:45 pm
ll00023
SubscriberThank you Rob. I will check the documentary again.
2700
2138
1355
1142
462
