November 7, 2018 at 2:13 pm
mh94
SubscriberHi,
I have done a few simulations for a multiphase flow consisting of solid particles and a fluid in a straight pipe. How can I generate the particle tracks at a certain time step?
Thanks in advance for any reply.
November 7, 2018 at 2:49 pm
Ansys EmployeeIf you have (DPM) particles in the domain then you can plot their location by reading that data set in and using the Results -> Particle Tracks. This should display a set of spheres/points representing the parcel positions.
November 8, 2018 at 12:24 pm
mh94
SubscriberThanks for your quick reply! I used steady solver and DPM with one-way coupling for my simulations. Unfortunately I didn't save the partial solutions for every nth-iteration. Is it still possible to display the particles e.g. after nth-iteration or certain flow time?
November 12, 2018 at 6:39 am
Keyur Kanade
Ansys EmployeeAre you using steady state flow with steady particle tracking or steady state flow with unsteady particle tracking.
For steady particle tracking, particles are tracked from injection point to final state.
For unsteady particle tracking, particle is advanced from its last position in previous DPM calculation.
Please refer to help manual for more information.
November 15, 2018 at 6:27 am
seeta gunti
Ansys EmployeeHi,
You can go through the following link which shows the particles tracks in multiphase flows.
Seeta
2688
2138
1351
1136
462
