Particle Tracking
    • Julen
      Hello everyone,
      I saw somebody evaluating how the particles mix with each other in an extruder. Is something like this possile in Ansys Polyflow? The sim I am running is using the polyflow solver.
      I am trying to do something like this. (This was created with Openfoam)
      Thanks in advance!
      If it's just particle flow and they're not being melted I'd look at Ansys Rocky (DEM code). That will couple to Fluent if the carrier fluid adds significant effects to the system.
    • Julen
      I don't really unterstand what you mean with your answer. Could you try to describe it a bit simpler? I am no expert when it comes to Ansys.
      Some additional Information, hope it helps:
      The solver I am using is the Polyflow solver and I am simulating an already melted polymerflow. I just impose a certain kg/hour inflow. I wanted to know if with those settings I am using I can somehow model the way particles would behave if I were to color them, like in the example I sent earlier.
      Thanks again
      OK, I don't use Polyflow.
      If you want particles in a screw feed than I'd use Rocky, possibly with Fluent. If I want to model a polymer extrusion I'd (ask someone else to) use Polyflow.
    • Julen
      Hello Rob, thanks for your help nonetheless. Do you know how I would ask someone else that knows polyflow? Do you have employees specifically for that?
      We do, I'll nudge the "manager" team to find someone.
    • Julen
      Any update on the nudging of the manager team 😅
    • Benjamin Ducoeur
      You can track particle using Polyflow using the module called Polystat.
      More information can be found here:
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/poly_ps/poly_ps.html
      There are several examples about the use of this module in the example manual:
      Example 50: The Rectangular Cavity
      Example 51: Coextrusion of Polymers in a Square Channel
      Example 52: Flat Die
      Example 46: Periodic Flow Through a Kenics Mixer
      Example 37: Mixer 2-D
      Example 65: Adaptive Meshing for Moving Parts; Mixer 2-D
      Example 91: Dispersion
      Example 116: Distributive Mixing Analysis in the Mixer GK7N
      I would focus on example 46 as it is like your application.
      In case you do not know, here is the link to find and use the Polyflow Example manual:
      https://support.ansys.com/KnowledgeResources/Solutions?solutionIdentifier=sol2064053&productName=ANSYS+Polyflow&productFamily=Fluid%20Dynamics
Viewing 7 reply threads
