Preprocessing
Preprocessing
Partition for better mesh
    • Stat
      Hello everyone,
      I am trying to create a mesh for a stent and some implications occur while doing it. I will attach all the relevant pictures in a pdf file. While meshing a single component of the stent's geometry the outcome is acceptable.
      The problem is when I add the other components of the stent. There seems to appear some problems with the mesh while maintaining the same parameters and partitioning. It looks like it is ignoring the edges that I have created in the corner.
      Does anybody knows the source of this problem or has a recommendation on the partitioning technique?
    • Aniket
      Ansys staff can not download images or any other documents on the student portal, so if you want to reach a larger audience to get answers from, please insert the images inline.
      -Aniket
    • Stat
      I appreciate the answer.
      I will attach the images below.
      Case 1:
    • Stat
      Case 2:
    • Stat
      I appreciate the answer and I apologize for the inconvenience.
      Unfortunately, when I post the case 1, a message occurs claiming that the post is being moderated.
    • Aniket
    • Stat
      I am using Ansys workbench.
    • Aniket
      I am sorry the background color threw me off, as we don't have such colors by default. So if I am understanding correctly you are using workbench meshing and from looks of it I think that can be a multizone method, and also from the looks of it the bodies are not sliced, but only faces seem to be split.
      And your problem seems with larger mesh size it ignores some face split? is it? if yes, multizone is a patch independent method, so if the larger file size is given, it will ignore your face splits. One thing you can try is give named selection to those edges that split faces so that they are respected by the multizone method.
    • Stat
      The method I am using is multizone. That is correct. The problem though, is when I add components of the stent to the geometry. When the corner of the stent is the only component, then this is the mesh I get:
    • Aniket
      You can try to add Face Meshing with mapped controls for the said faces and see if that helps.
      -Aniket
    • Stat
      This was the solution to my problem. I am really thankful!
Viewing 10 reply threads
