Tagged: batch-mode, fluent, journal-file, parameter, workbench
March 10, 2022 at 6:13 pm
TL111
SubscriberHi,
I's using workbench batch mode to run CFD analysis. I'm wondering is there a way to pass the parameter from bash script into journal file (a python script). More specifically, in the bash file, I call the a line and passing a parameter "user_param":
/projects/eng/software/ANSYS-19.5/workbench/v195/Framework/bin/Linux64/runwb2 -B -R /home/tongl5/scratch/TwoTruck_192/model_1/TwoTruck.wbjn --user_param=10
"user_param" is not a parameter in the fluent model so that I have to change it outside the journal file. then in the journal file (a python script), I want to use argparse to parse "user_param":
import argparse
parser = argparse.ArgumentParser()
parser.add_argument("--dp_file_name", help="dp_file_name", type=str)
args = parser.parse_args()
user_param = args.user_param
But It seems like that I cannot directly call "--user_param=10" in the bash script. Is there a way to solve it? Thank you.
March 16, 2022 at 10:57 pmRK
Ansys EmployeeHello,
Can you try this in a newer version?
2588
2080
1315
1108
459
