November 30, 2022 at 12:26 pm
ehsan.sadeghi
SubscriberHello
I have the following UDF structure for calculating gradients of UDS0 (potential). I start with calculation the UDS0 gradients in ADJUST macro, then I want to pass the calculated Ex, Ey and Ez to a SOURCE macro. My problem is that I am not sure if in my code structure Ex, Ey and Ez pass to Source function or not? how can I do that?
#include "udf.h"
DEFINE_EXECUTE_ON_LOADING(uds_names, uds_libnames)
void Set_User_Scalar_Name(int i,char *name);
Set_User_Scalar_Name(0,"potential");
Set_User_Scalar_Name(1,"E_x");
Set_User_Scalar_Name(2,"E_y");
Set_User_Scalar_Name(3,"E_z");
Set_User_Scalar_Name(4,"E");
Set_User_Scalar_Name(5,"n");
}enum
potential,
E_x,
E_y,
E_z,
E,
n,
N_REQUIRED_UDS
};DEFINE_ADJUST(grad_calc, domain)
/* calculate E_x, E_y, E_z; */
DEFINE_SOURCE(potential_source, cell, thread, dS, eqn)
real source;
source = 2.0*E_x;
return source;
December 1, 2022 at 11:53 am
Ansys EmployeeI tend to calculate the values for the source terms directly, so E_x etc would be in the DEFINE_SOURCE part of the code.
December 1, 2022 at 12:33 pm
ehsan.sadeghi
Subscriberso you mean I implment another DEFINE_ADJUST inside the DEFINE_SOURCE? or only the thread loop and face loop?
In DEFINE_ADJUST I calculate E_x, etc... then I need that parameter in source.
December 1, 2022 at 1:49 pm
Ansys EmployeeDo you need the DEFINE_ADJUST bit?
December 2, 2022 at 8:36 am
ehsan.sadeghi
SubscriberI don´t understand what you mean?
December 2, 2022 at 9:49 am
Ansys EmployeeWhat does the DEFINE_ADJUST do that can't be done in the DEFINE_SOURCE routine?
December 2, 2022 at 10:24 am
ehsan.sadeghi
SubscriberThat´s what I was asking. I didn´t know that it already loops over domain and executes per iteration. Thanks for being so nice!!
December 2, 2022 at 11:51 am
ehsan.sadeghi
SubscriberI did as you said, but for some reason I get error:
999999: mpt_accept: error: accept failed: No such file or directory
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 1228 RUNNING AT PC-ANSYS-157
= EXIT STATUS: -1 (ffffffff)
My code is:
#include”udf.h”
#define e 1.6e-19
#define epsilon0 8.854e-12
#define mu_p 1.35e-4
#define Dp 3.5e-6
DEFINE_EXECUTE_ON_LOADING(on_loading, libname)
Set_User_Memory_Name(0,”Potential Source”);
Set_User_Memory_Name(1,”Potential”);
Set_User_Memory_Name(2,”Ex”);
Set_User_Memory_Name(3,”Ey”);
Set_User_Memory_Name(4,”Ez”);
Set_User_Memory_Name(5,”Electric Field”);
Set_User_Memory_Name(7,”x-Momentum Source”);
Set_User_Memory_Name(8,”y-Momentum Source”);
Set_User_Memory_Name(9,”z-Momentum Source”);
Set_User_Scalar_Name(0,”Potential”);
Set_User_Scalar_Name(1,”ion concentration”);
}DEFINE_ADJUST(E_xyz,d)
Thread *t;
cell_t c;
thread_loop_c(t,d)
begin_c_loop(c,t)
C_UDMI(c,t,1) = C_UDSI(c,t,0) ;
C_UDMI(c,t,2) = -C_UDSI_G(c,t,0)[0] ;
C_UDMI(c,t,3) = -C_UDSI_G(c,t,0)[1] ;
C_UDMI(c,t,4) = -C_UDSI_G(c,t,0)[2] ;
C_UDMI(c,t,5) = NV_MAG(C_UDSI_G(c,t,0)) ;
C_UDMI(c,t,6) = C_UDSI(c,t,1) ;
end_c_loop(c,t)
}/* Sets the gradient of phi (UDS-0) to equal E_x (UDS-1) and E_y (UDS-2), and sets face values */
DEFINE_SOURCE(phi_source,c,t,dS,eqn)
real phi_source;
dS[eqn] = 0.0;
phi_source = -(e/epsilon0)*C_UDSI(c,t,1);
C_UDMI(c,t,0) = phi_source;
return phi_source;
}DEFINE_SOURCE(momentum_x, c, t, dS, eqn)
real source;
dS[eqn] = 0.0;
source = e*C_UDMI(c,t,2)*C_UDSI(c,t,1);
C_UDMI(c,t,7) = source;
return source;
}DEFINE_SOURCE(momentum_y, c, t, dS, eqn)
real source;
dS[eqn] = 0.0;
source = e*C_UDMI(c,t,3)*C_UDSI(c,t,1);
C_UDMI(c,t,8) = source;
return source;
}DEFINE_SOURCE(momentum_z, c, t, dS, eqn)
real source;
dS[eqn] = 0.0;
source = e*C_UDMI(c,t,4)*C_UDSI(c,t,1);
C_UDMI(c,t,9) = source;
return source;
DEFINE_UDS_FLUX(flux_ions,f,t,i)
cell_t c;
cell_t c0, c1= -1;
Thread *t0, *t1 = NULL;
real NV_VEC(A), NV_VEC(E_vec), E_flux = 0.;
real rho = C_R(c0,t0)+C_R(c1,t1);
c0 = F_C0(f,t);
t0 = F_C0_THREAD(f,t);
F_AREA(A,f,t);
if (BOUNDARY_FACE_THREAD_P(t))
E_flux = 0.0;
else
begin_c_loop(c,t)
F_UDMI(c,t,2) = C_UDMI(c,t,2) ;
F_UDMI(c,t,3) = C_UDMI(c,t,2) ;
F_UDMI(c,t,4) = C_UDMI(c,t,2) ;
end_c_loop(c,t)
c1 = F_C1(f,t);
t1 = F_C1_THREAD(f,t);
NV_DS(E_vec, =, F_UDMI(c0, t0, 2), F_UDMI(c0, t0, 3), F_UDMI(c0, t0, 4), *, Dp);
NV_DS(E_vec, +=, F_UDMI(c1, t1, 2), F_UDMI(c1, t1, 3), F_UDMI(c1, t1, 4), *, Dp);
E_flux = NV_DOT(E_vec,A)/2.0;
}if (i==1)
return (F_FLUX(f,t)/rho+E_flux);
else
return (0.);
2524
2066
1279
1096
457
