September 2, 2019 at 9:10 am
shivam321998
Subscriber -
September 2, 2019 at 10:39 am
Ansys EmployeeHow does the gap size compare with the minimum cell size?
September 2, 2019 at 11:54 am
shivam321998
SubscriberI've tried .1mm to.5mm as min size. The corrugated sheet and cylinder are different bodies. The method of attachment is surface contact between both. -
September 2, 2019 at 3:30 pm
Ansys EmployeeSurface contact, but there's a volume between those faces?
September 2, 2019 at 7:29 pm
shivam321998
SubscriberI mean to say that the cylinder is attached face to face with that volume which is a part of the corrugated sheet -
September 3, 2019 at 9:04 am
Ansys EmployeeIf you have created a multibody part can you check if you have contact regions, and if so whether they're correct. Contact detection is based on model dimensions, so 1m long parts with 0.1mm gaps can give a false contact and this can mess up the meshing.
September 4, 2019 at 9:08 am
shivam321998
SubscriberIn designmodeler I put all the bodies in one by creating a part so contacts don't get created. Meanwhile, I've tried meshing without putting all the bodies in one part, the meshing went fine but I got divergence error in fluent due to energy -
September 4, 2019 at 1:36 pm
Ansys EmployeeCan you check with the multibdy part that contacts aren't generated anyway: given the model aspect ratio it's possible you've got some.
September 7, 2019 at 11:09 pm
shivam321998
SubscriberI checked the number of parts in mesher and they're 3 as they should be visually. Anyway, I'm thinking of taking another approach i.e create manual contact between the common faces of sheet and cylinder and then meshing them by multizone method. I know that there wouldn't be a conformal meshing b/w two bodies, so what would be the problems with the result. -
September 20, 2019 at 3:10 pm
soto6942
Subscriberhello, can you generate a good mesh for the wavy figure ?, since I'm looking for help on the same topic
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2688
2138
1349
1136
462
