November 2, 2018 at 12:17 pm
chalasani
SubscriberPatch-conforming tetrahedral mesh failed because of duplicated faces in boundary mesh.
November 2, 2018 at 12:20 pm
chalasani
SubscriberHow to approach for the above error?
November 2, 2018 at 1:53 pm
Ansys EmployeeWhich meshing tool are you using?
As an aside, I've altered the title to something more useful than "KC". Please add details in questions so people can help you.
November 2, 2018 at 2:55 pm
November 2, 2018 at 3:53 pm
Ansys EmployeeNo worries.
I think your problem is the cell size. Have a look at the geometry and then work out what needs to be resolved: you need to make the cell size smaller than that dimension to capture the CAD. In this case the cells are big compared to the nozzles so it's linking bits of model that it shouldn't.
You also need to think about what you're going to model, and why. Is the petrol a separate phase, ie are you spraying petrol into air?
November 2, 2018 at 4:58 pm
chalasani
SubscriberThank you.
It is part of 2000mm long and 160mm diameter pipe, having nozzle head inside. Pipe already carrying petrol, nozzle head takes petrol and starts sprinkling to the other side with 6 different nozzles. Nozzle head will be placed at 800mm distance from one end. what would be the best way to approach this?
November 5, 2018 at 4:00 pm
Ansys EmployeeSo, are you modelling the nozzle, or the distribution of fuel in the head? Have a look at the sizing you need to resolve the features and then try meshing again.
November 6, 2018 at 8:30 am
Keyur Kanade
Ansys EmployeeWhen you get any error, use right click and use go to object. It points out the location or face where problem is coming.
Then change the settings accordingly.
You can check following video, though old, it gives good insights on meshing.
November 9, 2018 at 4:48 pm
chalasani
SubscriberHi
I am doing fuel distribution. I am trying to increase the number of bodies in design. I will update this as soon as I can.
Thanks & regards
KC
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
459
