Ansys Products
Ansys Products
Patching different areas in a 2D Multiphase VOF sim
    • Carlos Pfeiff
      Hello, I am trying to run a 2D model of a coating process, where part of it starts filled with ink, while the rest is air. I have just 1 part that makes up the domain (it is an import); how can I patch different areas of this domain with different volume fractions of ink? Right now, when I go to Patch, there is no option to create a new Zone, should I create it somewhere else?
      Thank you for your time.
      If you have separate cell zones created in geometry and labelled in meshing it's easier. However, if you use the Registers https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_ug_surf_sec_cell_register.html  you can patch those.
