3D Design
3D Design
Pattern from a Sketch in Design modeler
    • krany3
      How to create a pattern from a sketch or from an extruded cut in design modeler?
    • Keyur Kanade
      please check following video.
      if it answers your question, please mark this as 'is solution' to help others on forum.
    • krany3
      I watched the video before. They create patterns from solids, but not from the sketches.
      If you want to copy a "hole" create the extrude and pattern the cutting face (boundary of the hole). It sounds odd, but you do pattern the hole.
      In sketch there is a copy function, but pattern tends to be a more practical approach.
    • krany3
      Thank you
    • Keyur Kanade
      Yes, you have copy function in sketch. You may want to use it. Pattern is easily available in 3d and is more useful.
      If you got the answers, please mark this as 'Is Solution' to help others on forum.
Viewing 5 reply threads
