Payload in the kinematic problem
    • javat33489
      When calculating two gears, how to specify the payload on the second gear?
      To see how much torque is transmitted from the drive wheel.
      If you do not set the payload, then the wheel will rotate just like that.
    • peteroznewman
      The load on the driven gear can be an applied moment.  If the driven gear is on a revolute joint, then a moment can be applied as a Joint Load.
      • javat33489
        well, what if the drive gear rotates at a given moment? I rotate the drive gear with a torque of 24 Nm, what torque should I set on the driven gear so that I can see what torque is transmitted to it from the drive gear?
