February 17, 2023 at 8:39 am
Mayadurai Krishnan Kamalakannan
SubscriberSince series coupling capacitor electrically breaks my tx pairs into two different nets, how should I simulate as a single net?
TIA for your support
February 17, 2023 at 8:48 am
SubscriberExpectation is to simulate as a single net from IC to Connector(including vias & capacitors)
March 2, 2023 at 5:09 pm
Praneeth
Ansys EmployeeHi,
Thank you for reaching out to us and your patience is much appreciated.
Please provide more details about your model to help us serve you better.
Best regards,
Praneeth.
- Maxwell, HFSS or Q3D?
- Error
3694
2564
1765
1236
592
