January 18, 2021 at 11:04 am
luca
SubscriberIs it possible to insert a PDF in a drawing?
Given that there is no support for EXCEL spreadsheet, this could be an acceptable (even if not ideal) workaround.
Thanks!
January 18, 2021 at 3:07 pm
Subashni Ravichandran
Ansys EmployeeHello Luca
You can only import 3dpdf format in SpaceClaim.
I would recommend you try importing an Image. You can also Vectorise the image.
For more details, please check this video
January 18, 2021 at 5:34 pm
luca
SubscriberSubashni Thanks for your prompt reply.
Vectorise is quite useful for other jobs but in this case I need to insert an Excel table composed of lines, numbers and text.
Vectorise is not a solution here and pasting an image is just a workaround because the result is not clear and sharp as is needed for a table.
I can paste straight from Excel to SC but most of formatting is lost.
I request to add support for 2D PDF and Excel file as OLE attachment.
Thanks again.
January 19, 2021 at 12:07 pm
We thank you for sharing your feedback. We will share your idea/input with the product development team. Our developers will pick it up for future versions based on the votes received.
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Dwg export error
- problem to access on the spaceclaim help
- Unexpected graphics error
- Discovery Getting Crashed
- BUG to correct is important
- Error messages running solver
- Critical error
- Discovery Live freezes with multiple load cases while topology optimization
3656
2534
1745
1226
580
